Hello People,
New MikroTik user here with the following issue on a new mAP-2n
I can tell that an earlier problem with the NAT network going down whenever WLAN was turned off has successfully been fixed. http://forum.mikrotik.com/t/solved-lan-doesnt-work-without-wifi/67841/1
However, I still end up loosing my NAT network whenever I turn off WLAN because Quick-Set automatically changes everything to CAP. All seems to work OK after WLAN turnoff until I touch any setting under Quick-Set in either WinBox or WebFig. At that moment the LAN disappears and the RouterBox is inaccessible. Only solution is a full reset. I can repeat this behavior over and over.
Interestingly an “Ethernet” state momentarily shows up in the Quick-Set menu in WinBox (but not WebFig) right after disabling wlan. When that’s visible I can see both the WAN settings and the LAN settings as would make sense. But as mentioned above, upon changing any of the settings, the LAN is lost.
This may very well be a bug that I’d like to bring to your attention. But I would also welcome if there was a permanent “ethernet-only” choice added to the Quick Set menu which would be activated if WLAN is turned off.
Please let me know if that’s a possibility.
Thanks!
