Possible to avoid loops using 6.41rc?
In this post I describe what is my problem:
http://forum.mikrotik.com/t/crs106-rstp-loop-protection-unreliable-broadcast-storm-using-6-39-3/113805/1
Long story short, I have got advise from support to try 6.41rc with the new bridge concept and hardware offloading. Support says that maybe the problem was due to broadcasts both on vlans and on untagged interfaces, which could not be handled in 6.39.3
In my test setup everything works fine using 6.41rc56 and I can pull and insert any cable between the switches, the RSTP prevents loop as desires.
In the “real life network” we were finally able to unplug cables and get rid of loops, then I upgraded all switches to 6.41rc56 and things looked fine.
But finally the loops arrived again, apparently upon some topology change.
Only CRS106es connected, nothing on Combo ports (i.e. no tagged traffic).
Right now I have broadcast at wire speed in on sfp4 on two of the switches. The rest are unavailable.
I thought that a config like this with RSTP should prevent any loop and give me redundancy.
What more can I do to prevent loops?
# Master script
# Customer switches
add name=bridge1
set [ find default-name=combo1 ] comment="Connected equipment"
set [ find default-name=sfp5 ] comment="Future port for service network"
add auto-isolate=yes bridge=bridge1 interface=sfp1
add auto-isolate=yes bridge=bridge1 interface=sfp2
add auto-isolate=yes bridge=bridge1 interface=sfp3
add auto-isolate=yes bridge=bridge1 interface=sfp4
add auto-isolate=yes bridge=bridge1 interface=combo1
/interface ethernet switch egress-vlan-tag
add comment="VID 1004 is added to sfp1-4" tagged-ports=sfp1,sfp2,sfp3,sfp4 \
    vlan-id=1004
/interface ethernet switch ingress-vlan-translation
add comment=\
    "Untagged traffic from equipment is sent out on sfp1-4 with VID 1004" \
    customer-vid=0 new-customer-vid=1004 ports=combo1
add comment="sfp1-4 + combo is in switch group" ports=\
    sfp1,combo1,sfp2,sfp3,sfp4 vlan-id=1004
add address=10.4.1.100/16 interface=bridge1 network=10.4.0.0
set allow-remote-requests=yes servers=10.4.0.1
add distance=1 gateway=10.4.0.1
/snmp
set enabled=yes
/system identity
set name=CSW-4.1.100
/system leds
set 0 type=interface-speed-1G
set 1 type=interface-speed-1G
set 2 type=interface-speed-1G
set 3 type=interface-speed-1G
set 4 type=interface-speed-1G
set 5 type=interface-speed-1G
/user
  set 0 password=******
Seems you’re mixing old “switch configs” and “bridge” configs. The regular STP (RSTP) or new MSTP implementation works fine for me w/6.41rc based switches connected to Cisco switching. The Cisco switching is running MSTP on some and RSTP on others to try and highlight compatibility issues. You may want to post or just personally draw out your network and the links. You’ll also want to ensure that STP is enabled across the board or at on switches where you don’t think you have a loop you might.
Just because a port is sending untagged traffic doesn’t mean it isn’t capable of looping. It would just confine the loop to that VLAN. Additionally w/STP and RSTP everything happens untagged and isn’t VLAN aware like VLAN aware PVSTP in Cisco. So if you’re mixing links and allowed VLANs you may also create a loop when you don’t think there is one. I’m really happy to see MSTP in MIkroTik as it let’s us make something like PVSTP that so many of us grew up with.
Thank you for your reply idlemind, although it doesn’t appear to be quite idle :wink:
Using the new bridge concept was by advice from support. Do you consider this setup to be less than ideal, and vunerable with regards to loops?
I know I can setup bridge VLANs but they have a considerable impact on CPU, which switch chip setup hasn’t.
Yes I understand that ports carrying untagged traffic might loop, my mentioning this was because support suggested the mixing of tagged and untagged traffic as being a possible reason for loops not protected in pre 6.39.x
I have the posted config on all switches, all with RSTP.
Do you suggest that I try MSTP?
What about the Loop Protect feature on interface level?
This really puzzles me…
-All switches interconnected are CRS-106 with 6.41rc56
-All have the same config as posted above (only IP and name differs)
-Multiple connections directly between same two switches and multiple “paths” via other switches
-No equipment connected for the time being
Should then loops be possible, no matter how you connect or double-connect the switches?
This is crucial for me to solve fast… :frowning:
If neccessary I can resort to bridge vlans instead of switch chip, and try MSTP if that is better…
Although I would be very happy to actually use these as switches…no number crunchers… :open_mouth:
Anyone?
