Possible to chage the DoH max connections setting?
I have a few of the errors shown in my attached pic. Sometimes quite a few sometimes none. But doing some research it looks like there are two settings that might effect it, but there doesn't seem to be any way to adjust them. Am I wrong? Should they be adjusted? Would that have any affect?
doh_error
doh-max-server-connections
doh-max-concurrent-queries
To help you better,
we would need a few more details,
such as your exact router model,
the RouterOS version,
and the export of your /ip dns section.
It is also worth checking if the issue might be related to the specific DoH server you are using.
Could you share which one you have configured?
Regarding those two parameters,
you can easily modify them via the terminal just like any other RouterOS setting.
Finally, could you please paste the text of the error into the forum instead of just sharing an image?
This will help other users find this topic if they encounter the same issue.
Thank you!
Disclaimer: This answer was NOT AI-generated, but it was translated with Google Translate and artificially removed the abruptness of the response with Google Gemini.
It may contain translation errors and the person who provided the original text may be wrong, because they is human.
Router is a hex - RB750Gr3 with 6.49.20.
servers:
dynamic-servers:
use-doh-server: https://dns.nextdns.io/5f35c7/main
verify-doh-cert: yes
allow-remote-requests: yes
max-udp-packet-size: 4096
query-server-timeout: 2s
query-total-timeout: 10s
max-concurrent-queries: 100
max-concurrent-tcp-sessions: 20
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 60KiB
DoH being used is NextDNS.
I don't know what's causing the issue but after doing some reading of others having the same problem, and seeing that those settings existed which I did not know before because they don't appear in webfig or winbox, I thought that it might be a reasonable step to take to try changing them slightly to see if that does anything. If not it would seem an easy thing to change back.
The reason that I thought that it might be the router as opposed to the NextDNS itself is that this does not seem to happen on any other device I have it on and after reading numerous topic by others it seems as though the issue might be with the mikrotik. Perhaps not but that's why I began diagnosing so that I might eventually lead to the answer. What I did not see in any of my searches was what exactly to type into the terminal to adjust those settings and, perhaps more importantly, what to type to change it back if it does nothing.
Because you have 6.49.20 and are 7.2?.? settings
Ah, OK. That would make sense then. Just to be clear, so you are saying that the DoH settings are only available in the new 7 firmware and don't exist in the older v6 firmware? So not only are they not visible in Winbox but they are not able to be changed in terminal either? I just want to make sure that it's not just that they are not visible in Winbox but are able to be changed in terminal.
I wrote clearly, there is nothing to interpret.
