Possible to connect to Alvarion/Breeze Access AP??
I have a small wisp in my area that was bought by a local company without a technical/wireless guru. They run a Breeze Access Ap model AU-NI. I have one of their antennas and they are 2400 - 2500 but the “technical staff” says the radios freq hop. I am helping them a bit and would really like to use Mikrotik clients. Is it possible to connect and what do I have to do. TIA
JV
Hardware RB333 and R52. Using one of their antennas for testing with clear LOS.
No, not possible. Where are you located? May be able to help you more offline with AV/BA
