Is it possible to share a single DHCP server and its networks and pools over one or more interfaces?
add them to bridge
Bridges in the Mikrotik OS confound me. I tried a bridge before I created the new DHCP server, but couldn’t get it to work. The docs are a bit cryptic and trial and error didn’t bear any fruit. Care to layout the 5 point crash course in bridges?
I doubt this is!
http://www.mikrotik.com/testdocs/ros/2.9/interface/bridge.php
[]Create bridge.
[]Add interfaces of interest to the bridge, as ports.
[*]Create dhcp server on the bridge interface.
All devices connected to any of the interfaces added above will obtain ip from the dhcp server on the bridge.
Thanks, this worked. As I previously stated, I tried a bridge before but when I added the Interfaces as Ports and assigned the DHCP server to the bridge, each interface’s role under Bridge/Ports would come up as Disabled. I supposed Order-of-Operations is important.
Unrelated sidenotes:
I’ve always found the docs to be a bit cryptic: light on real-world examples, the language is a bit off (English-wise), and it assumes a base amount of knowledge about the topic. I suppose that’s what the Forums and the Wiki are for!
Tags/taxonomy that mirror the MikrotikOS interface would be a welcome addition to the forums - then I simply search by the “IP / DHCP Server” category and perhaps find what I’m looking for.
