Possibly bug in 6.37 disabling packages ?
Hi, I have updated a few RB750, RB850Gx2, RB1100AHx2 to 6.37 and when finish updates in this Routers, the wireless packages show enabled… y enter in system-packages, select disable and router say that disable will be done when reboot, reboot but package always still enabled after reboot and show “Wireless” in the winbox left menú…
Is a bug? Or I am doing it wrong?
Tried with winbox 3.4 and winbox 3.6 with the same result…
Can anyone help me?
Best regards!!
It is a bug.
Hi, but it´s confirmed? Because I search the first days from release this version and no info about this in the forum.
Thanks!!
changelog from 6.37.1 (releasing later today):
*) package - fixed wireless package status after upgrade to 6.37;
Oh great!! Thanks a lot
Best regards!!
