Hi all,
Please assist, what is the correct fetch command in 6.47.4 for the following Curl command
curl -i -XPOST 'http://192.168.aa.bb:8086/write?db=lte' --data-binary 'rssi,device=lte value=-50'
Many thanks
Hi all,
Many thanks
Hi all, just an update
/tool fetch http-method=post http-data="rssi,device=lte value=-60" url="http://192.168.aa.bb:8086/write\3Fdb=LTE"
Is working, however the “–data-binary” is not explicitly set yet.
Please note the ? as**\3F**
better is report RSRP, SINR, CQI
I would like someone to help converting curl command for me, like above
thanks in advance
curl -d “{"number":"112233445566778899","message":"text here"}” -H “Authorization:token_id” -H “Content-Type:application/json” -X POST https://site_teste.com
