PostCast SMTP server and DUDE
If anyone is looking for a good SMTP server to use, I have tested the PostCast SMTP server running on the same PC as DUDE. You can allow connections only from the local computer, specific IPs, local LAN, or more.
Free version:
http://www.postcastserver.com/download/release.aspx?p=3
There is a pro version also that allows multiple gateways, etc.
