Potential bridge issue?
This is a little complicated so I’ll explain as best I can
I’ve a small network here of 3 sites currently which connect to eachother through bridged WDS Rocket backhauls.
Each site has an RB450G and routes with OSPF, Site 2 is the only site with a ToughSwitch Pro so i’m using doing a router on a stick config for all sites as I will add Toughswitches to all sites later.
The 10.255.255.0/30 are on vlan 10 throughout the network and I have the Rocket backhauls & Toughswitch set to only passthrough vlan 10 so no other vlans pass between sites.
Basically since the Rocket backhauls are bridged, Site 3 is able to see Site 1 via Layer 2 (without having to go through the router at Site 2), is this a problem?
Perhaps I should be using a different vlan when going to each site for total seperation?
The network runs fine, everything traces properly but if I add some test addresses like 192.168.30.1 at Site 1 and 192.168.30.2 at Site 3 they will be able to connect directly.
