I have 2 sites up for internet to supply.The 1st site gets http://www.msn.com when we conect to it.The 2ed site also conect to the 1st site but all websites work acsept http://www.msn.com.what can the problem bee on this issue.All the dns setting are in ..
This resolved is from the MT or machine??
what are the dns setting??
Maximiliano
my firs routerboard work fine with dns settings 196.25.1.1 and 196.25.1.11.It starts with the second one that is link to the first one and i have put its dns on the same settings.If i put my old pc back with 2.8.?? all is working fine.It started when i got my new MT and installed it
change the mss tcp syn packets to 1360 or lower
Try to use tcptraceroute to msn.com on port 80 and look where’s stop.
Maximiliano
where do i set that under what
have done it and it stops at
63.218.94.17
it goes out to net
Marius, have you fixed your MSN / ABSA problems yet?
-B&H Special Milds
Ja Broer
Got the load balancing shorted out over 8 lines with no broken sites and working well
