Power brick for CRS125 Cloud Switch
I own a Mikrotik CRS125-24G-1S-IN Cloud Switch but I’ve lost the power adapter. The power socket indicates DC 10 28V. Anyone has an idea what might be appropriate power brick I should buy to replace it?
Original is a 24V 0.8A, center post positive. Are you needing the jack dimensions? Otherwise anything within the voltage you listed and above the wattage would be sufficient. (@12V you should get double specified amps @1.6A or higher).
