I have a board on which power cycle ping ip address was set via a script with command /interface ethernet poe set ether5 power-cycle-ping-enabled=yes power-cycle-ping-timeout=15m power-cycle-ping-address=X.X.X.X. Now I have to find X.X.X.X. I cant figure out a command for it. I tried /interface ethernet poe print. but it does not give ip address.
“print” is just a list of entries. To get a full config, you need to use an “export” command:
/interface ethernet export
or
/interface ethernet poe export
(I don’t have RB with poe available right now so I can’t check which one is it)
Thanks for answering. I tried both /interface ethernet export and /interface ethernet poe export. Both print this output
feb/20/2019 02:35:49 by RouterOS 6.42.5
software id = EKAF-R2MH
model = RouterBOARD mAP 2nD
serial number = 71E00617C0C1
Is export supposed to write config to a file? I cant see any file being created? What am I missing?
Ok got it. It is /interface ethernet export verbose.
