at one install right now, a concrete high-rise on the beach, 20 stories high. we have 1 wrap2c with 2 x NMP-8602’s In AP MODE on EACH floor. theses are to serve guest wifi laptop people..so we get a mix of all kinds of client cards and combos
each of the 2 NMP-8602 radios, on each floor is connected to a 17dBi Pac wireless 90 degree sector antenna (the like 4 ft long ones). These are then mounted with the brackets (in reverse) directly to the wall, each on a different wall facing different directions.
(all 20 of the access points are hard wired back to a switch)
This all works pretty well to cover all of every floor. HOwever i have some complaints and ALOT of the wierd disconnected messages in the logs…i attribute this to the crappie 8602s…
My question is this, if i change out all the 8602s to CM9s (which i have been testing and love) what kind of power hit am i looking at considering that the cm9 is 63mw and the 8602 is 400mw…this is fed into that 17dbi antenna remember.
thanks for any input.
