power supply no load
Hi all, newbie here.
I have bought ( wonderful :slight_smile: ) SXT2 (and HAP ac lite); would like to install a on/off switch in SXT2 power cable. Is it ok to keep PSU on with no load?
Thanks.
Sorry if wrong subfoorum.
Efectively, you will cut the power cord before the PoE injector, and are asking if leaving the PSU plugged-in is OK?
Yes, there is no problem.
Great, thanks.
Just one more quick question; is the “transmit power” in wireless specs same as EIRP ?
EIRP depends on the local regulations, if you will select the country in the configuration, it will lower the EIRP to match the local law. You will have to provide the antenna gain yourself in there.
The specifications list the total output power of all chains, on the board, not taking antenna into account.
Okay, I’ve set the country and antenna gain to 10dBi.
But, er, I’m using it indoor. Should I increase the antenna gain to compensate for that?
Thanks.
This is exactly what you should do.
but, how much? I couldn’t find the difference between max EIRP outdoor vs indoor for Serbia, 2.4GHz.
