Power System (UPS)
can anyone recommend a UPS system with:
  • E-Mail Alert
  • SMS Alert
  • SNMP
  • Web Interface
  • Big battery pack (Up to 100A)
Regards.
see restlesspowerbox.com - If you will come to MUM in Warsaw - we will be there to discuss your needs
Restlesspowerbox have a 3 problem:
1 - Top version have only 8 PoE port ( i need a modular system… up tu 10 ports)
2 - Battery pack is too small ! Only 7Ah !!! If connect a battery pack of 300 Ah the time for charging is long
3 - 1600 Dollar (with all plugin and only 8 PoE port) ??? Eltek have a battery pack system for half of this price… but not have a gsm system and work only on 48v
:frowning:
Convenient and affordable solution for batteries up to 60 A * h.
P S C-60 - http://www.meanwell.com/search/psc-60/default.htm
Must be connected in series, two such devices.
Of course this requires two batteries, and it was good.
The output will be from 21 to 27V.
The rest can be easily done by eating it comes to MikroTik.
OK but this is only a power supply with battery charger…
How i can manage this system ? How this system alert me ? Support remote control (ex GMS/SMS) ?
Here is an example of a slightly similar system: http://tandem.ck.ua/img/electronics/ups/ups_mt24B1sch.png
For GSM signal I use is: http://oko.plys.kiev.ua/oko-s.htm or http://oko.plys.kiev.ua/oko-u.htm
Such devices must be in your country.
For signaling , you can use UPS-MT-monitor plus service SMS the Internet.
