Hi, is anyone try to use 24Watt (24VDC 1A) poe to power up the RB800
- 1 wireless card???
as most my equipment is running on 24VDC, so i plan to power up with 24Watt poe, but worry there may some side effect.
You must short the JP5 jumper, then it will work.
if it shorted, it use the DC jack or i can use the POE???
JP5 - DIS POE Jumper
This jumper will disable the 802.11af compatible smart PoE, and also lower the undervoltage protection
threshold to approx 10V, allowing to use this device with passive PoE in 24V Solar power installations.
is the RB800 performance remain the same if i using 24Watt poe???
Router will not become slower, however i would suggest against use of 4 high power cards in such configuration
Janisk, i use only 1 dbii F50-Pro wireless card, this should no issue right…
should have no issues. Or should not be different form 48V PSU
