PowerBox Pro and 48 V 2 A 96 W
Hi, Guys!!
I need to powered some IP Cam’s and consider to use Power Box Pro and 48 V 2 A 96 W.
Can I powered PowerBox with 48 V 2 A 96 W through PoE Injector at eth1 and then supply cameras with 802.11af from ports eth2-eth5?
Is that possible?
Thank You
Yes, brochure is pretty explicit about that. RBGPOE injector is rated at 2A, so things should work just fine.
