Powerbox Pro - Viewing total power usage.
We have a Powerbox Pro utilizing 4 ports for POE. Randomly we will get a “poe-out, warning” "ether5 detected poe-out status: overload. The ports are setup as follows:
ether1 - radio using external POE injector (not supplying POE to powerbox)
ether2-ether5 - radio using Powerbox Pro POE and using between 6.4W-7.7W (24V and ~300mA)
sfp-1 - SFP Copper rj45 module to radio using external POE injector
My question is is there an option in winbox to see the total draw for the powerbox pro connected via power adapter? I can see the individual power draws on ether2-5, but can’t see the total power usage of the unit as a whole to see if I’m over budget for the specifications. Thank you in advance for any help you can provide!
For this particular device “total power consumption” is not implemented.
