PowerBox Pro + wAPac Constantly Rebooting
Hey,
I have a PowerBox Pro powered by a 1.6A 24V power brick through Port 1. Attached to Port 2 I have a wsAP ac, and a wAPac to Port 3. The wsAPac is functioning correctly, but the wAPac keeps rebooting. I’m not really clear why? Thoughts?
-Eric
What does log in Powerbox says?
Just says link down… Then link up. The access point says rebooted without proper shutdown.
Sent from my Pixel XL using Tapatalk
Does the WAP get POE from the Powerbox?
If yes there must be more in the log!
What ROS Versiin you are using?
How the Powerbox is connected to the Power Supply?
Over the POE in or directly to the Power socket?
The PowerBox get’s power from a POE Injector with a 24v 1.6A adapter plugged into it in another room connected via Port 1. The wsAP also gets power via the PowerBox via Port 2. The wAP ac is connected to Port 3 and is the one having the problem. All I see in the logs for the wAP ac is a message about not being shutdown before reboot. I tried to tail the logs to see if there is anything there right as it goes down… nothing.
I enabled POE debugging in the log.
I see a few things. I see short_circuit followed by waiting for load on port 4… which is interesting because there is nothing plugged in to port 4.
If I enable POE on port 3 I see,
POE Status - wait for load.
POE Status - on
Ether3 link up (speed 1G, full duplex)
Ether3 link down
Ether3 link down
Ether3 link down
etc… I only see the load on once… nothing else.
All are the latest rc.
can you please run this and copy the output here..
/int ether export
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] poe-out=off speed=100Mbps
set [ find default-name=ether5 ] poe-out=off speed=100Mbps
set [ find default-name=sfp1 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
