Specification of SXT LTE kit says that power consumption is 6W. Likewise SXT2 has rated power consumption of 11W. Together that’s 17W. With 24V power supply this means slightly more than 0.7A. Power adapter rated 24V 0.8A in theory should suffice.
However: certain products state maximum PoE output current to be 0.5A while I haven’t seen any such statement about PoE in max current. I guess it is safe to assume that 0.5A applies as well. Meaning that 0.7A of combined consumption is too much for SXT LTE kit input PoE. Solution would be to go with higher voltage … but SXT2 can only take up to 30V and even with that voltage, 17W still means current higher than 500mA . And this part also applies to PoE out on hAP ac.
So, in short: if it was my gear, I wouldn’t do it. Powering either SXT off PoE out of hAP ac is fine (single SXT consumes less than 0.5A @24V), but not combined. In any case make sure you’re using power jack on hAP ac, not PoE in.
