I am a bit confused with all that PoE standards, so I would appreciate some help.
I have ethernet cable which is plugged into Linksys LGS116P switch at home and it is powering IP camera mounted outside, everything works well and this is clear.
Now I want to mount second camera in same place where first is. but without using another ethernet cable. My idea was to unplug ethernet at home from Linksys, plug it to some PoE injector, on outside mount HEX POE and plug both cameras to HEX POE and power it from this injector. Will it work?
Cameras are Hikvision PoE 12V 802.3af. I see that HEX POE has 802.3af/at standard on output, but I am unable to find if powering method of HEX POE matters in this case? Do I need to power it via DC input to get 802.3af/at on output or can I power it via PoE injector. If yes then what injector do I need? 48V to match 802.3af/at standards or 12V will be enough?
Or maybe there is cheaper solution to get two cameras powered via one ethernet cable? Any suggestions?
I could buy RB260GSP, power it by 12V PoE injector, but I am not sure if that 12V passed further as passive PoE will power cameras properly?
