Dont’ worry.
The cap Ax itself uses 11W:
Max power consumption without attachments 11 W
that is the absolute max, in real world you will see more like 6-7 W.
But you can daisy chain to it another device (i.e. using the PoE out of the cap Ax), this device can be roughly another 20 W, and this makes, considering losses and what not, the total stated:
Max power consumption 36 W
So you won’t have any problem in powering just the capAx from the RB960PGS.
The capAx (even if may be not clear from the specs) can be powered both with “old” 24 V PoE and with “new” 802.3af/at 48V PoE.
Personally I wouldn’t spend nowadays on a hex poe, however, because it has a limited amount of storage (16 Mb) that is already tight with the current 7.x Ros versions and it is basically a router, and you don’t need the SFP cage, you might probably be better served by a small switch like the RB260GSP (that runs SwOS ) and is much faster at switching.
The issue (or non issue) in this case would be that the RB260GSP uses only the “old” (passive) poe at 24 V, so while your capAX is compatible with that, if you want to change the AP the new one may support 802.3af/at only and you will have to change the switch also.
You would save some money, however, at list prices 90-56=34 $.
The power supply that comes with the both the hex Poe (RB960GSP) and the RB260GSP is a 24V 2.5A one (60 W) more than adequate to power both the switch and the capAx, but if you want to use the “new” 802.3af/at with the hex PoE you will need to buy additionally a 48 V power supply, such as:
https://mikrotik.com/product/48POW
another 18$
or this :
https://mikrotik.com/product/mt48_480095_11dg
only 12$
If you are confused, it is normal, the current situation of Mikrotik PoE is madness.
The TP-Link suggested should be around the same price as the Mikrotik switch, it is 802.3af/at and has the “right” 48V power, with some 65W total, so it would be a good alternative.
