I’ve got a hEX S up and running on my network, and I’ve been trying to sort out the option of powering it by the 48V POE injector that I already had. I carefully checked that the POE injector does carry the voltage on the same pairs as Mikrotik is expecting, voltage within spec.
Here’s what happens: with the router off, plugging POE out on the injector into port 1, the router does not power on. The power LED flashes, along with the light on the side of the injector. What I’ve gathered is the flashing means that the injector cannot negotiate what’s on the other end. This is 48V passive, but apparently there is still some kind of checking going on.
I have also tried plugging in POE once the router is running under its own 24V power supply. The router sees that and changes to use POE. At that point, it can also provide POE on port 5 to my AP. I can even unplug the 24V power supply and things keep running. Even to the point where restarting in winbox has no problem. But if I lose power for any reason, it seems that I cannot get things running again with just the injector, I have to “jump” the router with its power supply.
I’ve seen a couple old threads that might have alluded to a setting on ether1 that would adjust the power negotiation coming in. I’m not sure if that may have been for a different product, or older version of RouterOS, because I can’t find anything in Winbox. Is there a setting for anything like this that I’ve missed?
Thanks.
