Hello dear experts,
I am trying to hook up a TPLINK TL-WA5210G to a RB750UP using its POE out functionality.
Ultimate goal is to power 2xWA5210G + 1 UBNT Nanostation Loco + 1 Mikrotik SXT using POE out function of RB750UP in a multi wan setup.
Running into trouble:
750UP fails EVERY TIME the WA5210G is connected on a POE Out port using Mikrotik PSU.
I did additional tests. I share them below in the hope that it may help resolving this issue:
- Using factory provided PSU for 750UP rated at 24v, 2.4A to power 750UP
When I plug the WA5210G CPE, all leds starts blinking crazy and the router fails.
Tried to change POE setting from auto to forced, no luck.
Tried on all ports 2-5 same result: all leds go crazy and the 750UP switch fails.
Tried to turn off POE except on one port before plugging CPE WA5210G, it fails.
Tried changing ether1-poe-in-long-cable setting from no (default) to yes, it fails.
Tried 10 different LAN cables, same result, it fails.
2) The 750UP POE Out works well when hooked to UBNT Nanostation Loco M2 + Mikrotik SXT using Mikrotik factory PSU (exact same unit as above, 24v 2.4A)
As soon as I hook up a WA5210G CPE, all leds start blinking crazy again and router fails.
The TPLINK CPE works well using its own factory provided POE injector (PSU rated at output 12v 1A)
Tried powering 750UP using the TPLink injector and PSU (12v 1A)
The RB750UP powers up fine and provides juice to TWO WA5210G on all ports 2-5. POE monitor shows around 10V 300mA and 3.5 W for each.
However this setup does to not work with 1 or 2 additional CPEs.
The router does not fail, howerver all CPEs start rebooting randomly (not enough power from PSU I suppose?).
My tentative conclusion:
It seems the problem can be narrowed down to a single WA5210G not working at all with 750UP POE out feature using factory Mikrotik PSU.
Could you please advise as to powering One TP Link CPE with 750UP POE Out using factory provided PSU (Point 1 above)?
Thanks in advance for your kind feedback.
PS: all items are brand new, and were delivered a few days ago.
All Ethernet cables length below 2 meters max.
