Powerline Pro Plug Type
Hello
I am wondering does the unit work over UK power cable plug type ? instead of the Type C used in Europe and the US ?
Thank you
Power cord on powerline pro is replaceable. If you manage to find one with UK plug, there’s no reason why powerline should not work …
Thank you for your feed back, I was wondering because every other product of Mikrotik has an option of a UK plug except the PowerLine has only a US and European plug options, I found that weird !
But yah lets see .
Thanks again .
Every other RB product (not sure about pro boxes with power adapters built in) doesn’t come with detachable cable, they come mostly with “brick” power adapters (which can be replaced with generic ones never the less). There’s simgle reason why this one comes with cable, not PA: it needs direct access to mains wires (not through PA). But then, what can be simpler than replace simple passive copper wire+plug with another one?
