i just want to know if a Wlan poynting antenna 2.4ghz would connect to a mikrotik Ap.
i want to know before i buy the poynting antenna.
thanks
thanks
If it is truly a 50 ohm 2,4 GHz antenna then you are fine. Manufacturer of it is not that important.
Hello. Yes, but poynting antenna is just an antenna.. what you need to do?
i want to create a bridge between two offices.
thanks very much for the response
Buy 2x 711 boards and a 5GHz enclosure with antenna..
it’s better 5ghz.
Poynting has one with 19dBi antenna..
