Hi everyone,
I'd like to hear your experiences with old MikroTik architectures (PPC and TILE) on RouterOS v6 and v7 Long-Term. I have both, and I'm not sure what to do.
PPC:
I have a PPC device that had serious issues on v7. Even after resetting the configuration, it still wouldn't work properly. After updating to a newer v7 build, my original config worked again. This looks like a RouterOS v7 system issue, not a config issue.
PPC devices are long EOL, and I suspect v7 support for them is not well tested. Has anyone else seen this on v7 LT? Is it common for PPC to fail after a config reset? Should I just stay on v6 LT for stability?
CCR1009 (TILE):
I also have a CCR1009. I've seen mixed reports about v7:
CPU usage going from ~75% to 100%
kernel errors / random reboots, fixed by downgrading to v6
upgrade failures, sometimes due to insufficient disk space
What do you recommend for CCR1009 now? Stay on v6 LT, or upgrade to v7 LT? If v7 LT, which version is safest? Any known upgrade issues?
Also, is v7 Long-Term actually ready for these older platforms, or is v6 LT still the safer choice?
Thanks for any input.
