i have a hugh problem ppoe connections.
i use mt version 2.9.41 and a radius server (external) and only 10 user
my network works fine and ppoe clients loged in. After a while 1 client log out automaticly, if another client log in. Somtimes a client log out without any reason. WLan connection is fine an works very well for testing i was only 1 m from the access point. if i reconnect the ppoe it works again for some minutes/ hours.
Pls can somebody help me?
thanks!
yenns
maybe someone can help. but you wont know that unless you post the necessary information. more information is better than less. if you dont know what to post, then post as much as you can possibly can.
I had the same problem just after configuring clients.
Check to see that the limit bytes in and limits bytes out in your pppoe secrets tab under PPP are not checked and have vallues.
This sets the limit for each pppoe session, and With the information that you provided this is the only thing that I could think of just off the top of my head.
To check the configuration log onto winbox,
Goto PPP
Then to Clients tab,
Select a client
Then check at the bottom of that window, there will be two options, one
limit bytes in disable this if enabled
limit bytes out disable this if enabled
If you do not wish to disable, then increase the limits, remember that 1Kb is 1024bytes.
Hope this was of help to you.
Another reason could be that you are using the unlicenced version, when you create PPPOE server, it only allows one queue, and when another person tries to log on, then that person will be disconnected as the router creates a queue for each client that logs on.
It will log on for about a second then disconnect and it will only connect one client at a time. I also had this problem when I setup a computer to run as PPPOE server at home, also the level 1 licence that is for home use.
