PPOE disconnecting
ether1 is connected to internet provider’s cable modem
ether2 is connected to PPOE client
ether3 is connected to laptop running Winbox
PPOE clients will be running perfectly fine and Winbox is running fine. I then unplug the cable from ether3 and the PPOE clients loose connection. Why does unplugging from ether3 cause issues with ether2?
Can you post the output from /export compact so we can get an overview?
