Network Map
I have a adsl modem in bridge mode going into port one of the mikrotik. The mikrotik uses ppoe to establish connection to internet, port two on the mikrotik goes to my network switch to the rest of network.
Ip Addresses
0 ;;; default configuration
address=172.16.0.254/24 network=172.16.0.0 interface=ether2-LAN
actual-interface=ether2-LAN
1 address=10.1.1.1/30 network=10.1.1.0 interface=ether1-WAN
actual-interface=ether1-WAN
2 D address=218.101.6.208/32 network=218.101.61.124 interface=pppoe-out1
actual-interface=pppoe-out1
IP Route info
0 ADS dst-address=0.0.0.0/0 gateway=218.101.61.124
gateway-status=218.101.61.124 reachable pppoe-out1 distance=1 scope=30
target-scope=10
1 ADC dst-address=10.1.1.0/30 pref-src=10.1.1.1 gateway=ether1-WAN
gateway-status=ether1-WAN reachable distance=0 scope=10
2 ADC dst-address=172.16.0.0/24 pref-src=172.16.0.254 gateway=ether2-LAN
gateway-status=ether2-LAN reachable distance=0 scope=10
3 A S dst-address=192.168.1.1/32 gateway=ether1-WAN
gateway-status=ether1-WAN reachable distance=1 scope=30 target-scope=10
4 ADC dst-address=218.101.61.124/32 pref-src=218.101.6.208 gateway=pppoe-out1
gateway-status=pppoe-out1 reachable distance=0 scope=10
interface info
0 R name=“ether1-WAN” type=“ether” mtu=1500 l2mtu=1526
1 R name=“ether2-LAN” type=“ether” mtu=1500 l2mtu=1524 max-l2mtu=1524
2 name=“ether3-slave-local” type=“ether” mtu=1500 l2mtu=1524 max-l2mtu=1524
3 name=“ether4-slave-local” type=“ether” mtu=1500 l2mtu=1524 max-l2mtu=1524
4 name=“ether5-slave-local” type=“ether” mtu=1500 l2mtu=1524 max-l2mtu=1524
5 R name=“pppoe-out1” type=“pppoe-out” mtu=1492
firewall info
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=
10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s
udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment=“default configuration” disabled=no
in-interface=pppoe-out1 protocol=icmp
add action=accept chain=input comment=“default configuration” connection-state=
established disabled=no in-interface=pppoe-out1
add action=accept chain=input disabled=no in-interface=pppoe-out1
related disabled=no in-interface=pppoe-out1
add action=accept chain=forward disabled=no dst-address=172.16.0.1 protocol=tcp
add action=drop chain=input comment=“default configuration” disabled=no
add action=dst-nat chain=dstnat comment=Winbox disabled=no in-interface=
pppoe-out1 protocol=tcp to-addresses=172.16.0.254 to-ports=8291
add action=dst-nat chain=dstnat disabled=no in-interface=pppoe-out1 protocol=
tcp to-addresses=172.16.0.1 to-ports=25
tcp src-port=3389 to-addresses=172.16.0.1 to-ports=3389
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out1
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
Thanks for your time.
