i’m writing for an help or tips,
i’ve an wimax connection through ppoe connection, my isp sometimes give internal nat ip address and i’ve to disable and enable ppoe connection to have external ip, the internal ip starts with 100.x.x.x . The external usualy are 78.x.x.x or 5.x.x.x
I’ve found this scripts but it does the opposite that i need.
Can someone help me? Thank you
Thanks to reply,
i changed the ppoe client name but there’s some error and i can’t solve it
first, it give me an error on second line column 32 but i tried something but i can’t pass it,
second $currip~“/^100./ with atom e mikrotik plugin highlights an error, i read the guide and try $currip~”^100*[0-9 \.$]" Is it right?
