Hello
Im trying to setup wisp. Do you have to define ppoe user in every MT ap or can ppoe AP pull client info from RADIUS server
if you have a Radius server, then you can make all Routers connect to this Radius.
Armin, one suggestion that I really MEAN:
If you plan on setting up a WISP, do yourself (and your future customers) a favour and really LEARN the things that are necessary for that. Information like the one you asked for should really pop in the eye on the first glance of the revelant manual sections…
Best regards,
Christian Meis
I havent done ppoe before so I would like to know how much can you do centrally without having to define every user/pass and user/IP combination in the router
PS!
How sensitive is ppoe session to interference on radio interface?
