ppoe gateway which i want to tell mikrotik router the ip of new devices to add to mikrotik arp list
So i can manage firewall on the tik from an incoming gatewAy and incoming dhcp
I was thinking
Dhcp relay?
Maybe Vlan is my answer or
Some sort of subnet config where tik recevies dhcp from the gateway and then i can apply layer 7 and raw firewall on the mikrotik and then forward this out to
//A switch where the switch is being issued dhcp from the mikrotik
And the mikrotik is being issued dhcp from the gateway..
