PPOE VLAN
Hi, my ISP needs VLAN to get PPOE session connected.
I actually did that with:
interface vlan add vlan-id=20 interface=sfp1 name=vlan20
interface pppoe-client add interface=vlan20 name=PPPoE_Out user=xxxxx password=yyyyyy use-peer-dns=yes add-default-route=yes
PPOE connects instantly, but the problem is I can’t get internet to work.
Do I have to untag or what am I missing?
Thank you
Have you added a NAT rule for LAN-to-Internet traffic? For recent versions of RouterOS it is simply a case of changing the WAN interface list - likely from ether1 (the usual default) to PPPoE_Out in this case.
Attach the vlan to the PPoE-Out interface not the sfp1 physical interface as you have done looking at your snippet (GOOD)
For interface list
vlan20 interface list=WAN
PPoE-Out list=WAN
sfp1 list=WAN
(all three just to be on the safe side).
if that doesnt fix it, need to see the rest of the code
./export hide-sensitive file=anynameyouwish
