Hi!
I use Mikrotik to work as BRAS, the ppp profile is:
1 name="ppp_prof" local-address=120.0.0.1 remote-address=ppp_pool use-compression=default
use-vj-compression=default use-encryption=default only-one=yes change-tcp-mss=default
I found for each pppoe session, Mikrotik will send out PPP CCP echo request every 1 sec, I do not think these CCP echo request packets are useful for the pppoe session, ang why Mikrotik will send out CCP ECHO request packets so frequently? Because I can not find a parameter to configure it.
Blue letters show 5 consecutive PPP CCP ECHO requests with tyhe period 1s.
No. Time Source Destination Protocol Info
3 1.970323 HewlettP_04:c8:0d 00:00:00_00:0b:02 PPP CCP Configuration Request
Frame 3 (56 bytes on wire, 56 bytes captured)
Ethernet II, Src: HewlettP_04:c8:0d (00:11:85:04:c8:0d), Dst: 00:00:00_00:0b:02 (00:00:00:00:0b:02)
PPP-over-Ethernet Session
Point-to-Point Protocol
PPP Compression Control Protocol0000 00 00 00 00 0b 02 00 11 85 04 c8 0d 88 64 11 00 …d..
0010 00 0f 00 06 80 fd 01 0b 00 04 00 00 00 00 00 00 …
0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
0030 00 00 00 00 00 00 00 00 …No. Time Source Destination Protocol Info
4 3.090559 HewlettP_04:c8:0d 00:00:00_00:0b:02 PPP CCP Configuration RequestFrame 4 (56 bytes on wire, 56 bytes captured)
0010 00 0f 00 06 80 fd 01 0c 00 04 00 00 00 00 00 00 …
5 4.180743 HewlettP_04:c8:0d 00:00:00_00:0b:02 PPP CCP Configuration Request
Frame 5 (56 bytes on wire, 56 bytes captured)
0010 00 0f 00 06 80 fd 01 0d 00 04 00 00 00 00 00 00 …
6 5.310992 HewlettP_04:c8:0d 00:00:00_00:0b:02 PPP CCP Configuration Request
Frame 6 (56 bytes on wire, 56 bytes captured)
0010 00 0f 00 06 80 fd 01 0e 00 04 00 00 00 00 00 00 …
7 6.211155 HewlettP_04:c8:0d 00:00:00_00:0b:02 PPP CCP Configuration RequestFrame 7 (56 bytes on wire, 56 bytes captured)
0010 00 0f 00 06 80 fd 01 0f 00 04 00 00 00 00 00 00 …
Could I disable LCP CCP in Mikrotik? I am using v2.9.27
Best Regards
