PPP-Chain problem.
Hello, I’ve got problem with adding chains to my ppp chain.
I got a total of 25 chains, but when I add a chain with a sequence number above 19 to a ppp-profile, the log says that the chaincould not be found.
The chains above # 19 could be refered to from other chains and they works. I’m running 2.8.27.
Have anyone experienced the same problem?
Is this a bug or does the ppp-engine only handle chains with sequence number lower then 20?
Br, Paul
I do not know if it’s a bug or not but first
send a supout file to support@mikrotik.com
There have been similar bugs not long ago with other things that can be “Add”'d
this has been fixed in 2.9
Do you mean to say that it is fixed in version “2.9 RELEASE-CANDIDATE 4”, or “v2.9-NOT-READY-FOR-PRODUCTION-4”? :stuck_out_tongue:
in any 2.9 version it works fine. all new bug fixes go into 2.9, as it is already very near Final.
Thanks Normis! I will wait for the release of 2.9
