PPP-Client (3G) (USB)
Did the PPP-Client code get the same “keep alive” updates thet were intriduced (I heard) in the last couple of 3.X versions?
I am seeing a large amount of drops and re-connects that I thought would have been fixed with the keep alives…
Also..
Still having issues with winbox forcing a reconnect when a PPP-client connection has been running stable for a couple of hours…
If you click on the “ststus” tab of the particular ppp-cleint connection, the connection will drop and reconnect.
I can provide examples and a target router…
