PPP compression - L2TP and Windows
Can someone please tell me if compression works between a mikrotik running as an L2TP/Ipsec VPN server and a windows 10 user connecting using the built in client?
If so, how can i see that this has been negotiated?
What sort of compression is in use? (i.e is it just header compression or is there some proper data compression going on… I realise there are limits to how good it can be with <1500 bytes to work with.. but i have seen softether do some pretty good compression with easily compressed files and I’d like to get that out of our Mikrotik setup)
