PPP COUNT to EMAIL
Hi we have an interesting scenario, we would like to monitor the amount of active ppp sessions and alert us if the count is less than a pre-defined threshold.
This would help with monitoring, as we can see if there is network issues without needing to monitor all our access points and individually.
Very poor example: /ppp active print count-only (if count < X, then EMAIL=Support@isp.com)
Dainen - wwwires.com
So what exactly do you need?
To query the amount of active ppp sessions on our boarder router, at a 5 min interval,
Then email us if it the count of those active sessions is below 175.
I do it manually now to check if the network is running and customers online.
Thanks for the help.
Dainen
    :local pppCount [/ppp active print count-only];
    :if ($pppCount < 175) do={
        /tool e-mail send from="me@test.com" to="admin@test.com" server=<mail_server_ip> subject="ppp count" body="Only $pppCount active connections";
Add this code to system scheduler with interval 5minutes.
Cannot thank you enough !!!
Regards,
Dainen
Hi again, would there be any chance that you could help re-write it for 2.9.48 Router OS.
It is our main boarder router and i don’t want to upgrade it for a little while yet.
I tested it on our v3 router and it works brilliantly.
Thanks,
Dainen
