PPP Interface
Hi all,
I can see at PPP–>Interface that in name column appears my pppoe clients that way p.e. but for some reason, some times appears like . I mean the same pppoe adding -1. My question is way?
Maybe this pppoe is used by more than one user? I look for the pppoe and only appears once and with -1.
If I remove it from active connections, connects again but without -1.
What that -1 means? :confused:
New client is being generated by naming it with numbers -1, -2 etc. If there is no need to autogenerate those then maybe it is just a new bug in ROS.
Btw: The ppp-out interface is prone to having similar “issues”.
Thanks Ivoshiee,
but can’t understand “New client is being generated…”
does it means that more than one client has the same pppoe?
or even the same client disconnects an reconnects and pppoe server didn´t refresh well this situation?
How could I test the problem…
