Hi to all
i have two sides , Side A is my Server and Side B is my clients . Side A and B are connected via DWDM Fibre Network and its under same VLAN configured by the DWDM network , the Fibre network depend Cisco 2560 switch and its not support QinQ .
My goal is to let the clients at side B to have broadband connection on PPP SERVER A , i have configured like this :
on Side A
PPP server over EOIP tunnel and the QOS is Megis QOS “Marking packets and queuing”
Side B
only bridge between EOIP and Eth2 , while Eth2 connected to the PCs that its need to have broadband connection .
its work well but the problem that the QOS will see the EOIP interface as one user and all users under this EOIP will be shared in the rate limit that its should go for each user .
in normal cases when there is no DWDM i use VLAN instead of EOIP , but in this case i can not use VLAN as it will not work .
i made small test .. i configured EOIP between Side A and B and i have put the VLAN under the EOIP and configure the PPP server the VLAN and its work but the QOS is bit confused ..
any post and support is highly appreciated
thanks
