Hi.
Recently acquired an internet link that use a PPPoE connection, but in my RB750, the interfaces menu does not appear the PPPoE option, even with the ppp package installed and enabled. Details of my router:
Model: 750
Current Firmware: 3.09
OS Version: 6.33.1
License: 4
PPP package installed and enabled: version 6.33.1
Console:
[admin@MikroTik] > system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 user-manager 6.33.1
1 security 6.33.1
2 routing 6.33.1
3 mpls 6.33.1
4 dhcp 6.33.1
5 advanced-tools 6.33.1
6 system 6.33.1
7 routeros-mipsbe 6.33.1
8 X system 6.33.1
9 X wireless-cm2 6.33.1
10 X ipv6 6.33.1
11 wireless-fp 6.33.1
12 hotspot 6.33.1
13 X dhcp 6.33.1
14 X mpls 6.33.1
15 X routing 6.33.1
16 ppp 6.33.1
17 X security 6.33.1
18 X advanced-tools 6.33.1
[admin@MikroTik] > interface ?
An Interface is physical or virtual device which provides a connection to an external network.
.. -- go up to root
blink --
bonding -- Interface bonding
bridge -- Bridge interfaces
comment -- Set comment for items
disable -- Disable interface
dsl --
edit --
enable -- Enable interface
eoip -- Ethernet over IP tunnel interface
ethernet -- Ethernet interfaces
find --
get -- Gets value of item's property
gre --
ipip -- IP over IP tunnel interfaces
lte --
mesh --
monitor-traffic -- Monitor traffic
print -- Print interface summary
set -- Change item properties
traffic-eng --
virtual-ethernet --
vlan -- Virtual LAN interfaces
vpls --
vrrp --
export -- Print or save an export script that can be used to restore configuration
What`s wrong? Any help?
