A quick question:
Can one ppp profile be used in multiple different pptp/sstp.. tunnels or best practise is for each tunnel to have separate ppp profile (even if profiles settings are same…) ?
A quick question:
It can otherwise it wouldn’t have sense.
I’m asking this because in this thread:
http://forum.mikrotik.com/t/solved-problem-with-vpn-traffic-on-certain-ssl-destinations/81133/1
I’ve described a problem which was caused by two things:
When I’ve changed to correct MTU value, and when I’ve used a separate ppp profile (same values inside), I’ve solved the problem descrived in thread..
I am using the same sstp profile for client’s as well for server’s connections at the same time without any problems.
