pppoe , 2 wan , one for all browsing and one for ym n skype
hello guys, i am using pppoe to provide internet for 150+ clients in compound. i have 10 mb DSL link..
now as customers grows they complain abt yahoo messenger , skype voice chat.. am planing to add one more dedicated bandwidth 512 kbps for yahoo messenger… here is my presenet configuration…
# jan/01/1970 03:05:50 by RouterOS 3.24
# software id =
set 0 arp=enabled auto-negotiation=yes comment=Internet2 disabled=no \
    full-duplex=yes mac-address=00:0C:42:3B:95:51 mtu=1500 name=ether1 speed=\
    100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
    "---- Internet-1----" disabled=no full-duplex=yes mac-address=\
    00:0C:42:3B:95:52 master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="\
    ------------------------------------------------     Compound Internet-Use\
    rs         --------------------------------------------" disabled=no \
    full-duplex=yes mac-address=00:0C:42:3B:95:53 master-port=none mtu=1500 \
    name=ether3 speed=100Mbps
add name=pppoe-pool2 ranges=10.10.2.10-10.10.2.254
add name=pppoe-pool next-pool=pppoe-pool2 ranges=10.10.1.10-10.10.1.254
/ppp profile
set default change-tcp-mss=yes comment="" name=default only-one=default \
    use-compression=default use-encryption=default use-vj-compression=default
add change-tcp-mss=no comment="" local-address=10.10.1.1 name=pppoe-profile \
    only-one=yes rate-limit=64000/512000 remote-address=pppoe-pool \
    use-compression=default use-encryption=default use-vj-compression=no
add change-tcp-mss=default comment="" local-address=10.10.1.1 name=pppoe-res \
    only-one=default rate-limit=64000/64000 remote-address=pppoe-pool \
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 \
    sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 \
    red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=\
    5
set default-small kind=pfifo name=default-small pfifo-limit=10
/queue simple
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment="" \
    direction=both disabled=no dst-address=0.0.0.0/0 interface=ether2 \
    limit-at=8k/8k max-limit=64k/64k name=P2P p2p=all-p2p parent=none \
    priority=8 queue=default-small/default-small target-addresses=\
    10.10.1.0/24 total-max-limit=128 total-queue=default
/routing bgp instance
set default as=65530 client-to-client-reflection=yes comment="" disabled=no \
    ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
    no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
    redistribute-static=no router-id=0.0.0.0
/routing ospf area
add area-id=0.0.0.0 authentication=none disabled=no name=backbone type=\
    default
/system logging action
set memory memory-lines=500 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=500 \
    disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=0.0.0.0:514 src-address=0.0.0.0 \
    syslog-facility=daemon syslog-severity=auto target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
    boot-protocol=bootp cpu-frequency=680MHz enable-jumper-reset=yes \
    enter-setup-on=any-key force-backup-booter=no
/user group
add comment="" name=read policy="local,telnet,ssh,reboot,read,test,winbox,pass\
    word,web,sniff,!ftp,!write,!policy"
add comment="" name=write policy="local,telnet,ssh,reboot,read,write,test,winb\
    ox,password,web,sniff,!ftp,!policy"
add comment="" name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy\
    ,test,winbox,password,web,sniff"
/user
add address=0.0.0.0/0 comment="system default user" disabled=no group=full \
    name=admin
add address=0.0.0.0/0 comment="" disabled=no group=full name=hadi
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
    no
/interface ethernet mirror
set mirror-port=none source-port=none
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=\
    default-encryption enabled=yes max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
    default enabled=no keepalive-timeout=60 mac-address=FE:6F:98:26:35:02 \
    max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pppoe-server server
add authentication=pap,chap,mschap1,mschap2 default-profile=pppoe-profile \
    disabled=no interface=ether3 keepalive-timeout=10 max-mru=1480 max-mtu=\
    1480 max-sessions=0 mrru=disabled one-session-per-host=yes service-name=\
    Internet-Compound
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
    enabled=yes keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.1.10/24 broadcast=192.168.1.255 comment="" disabled=no \
    interface=ether2 network=192.168.1.0
add address=63.117.24.1/27 broadcast=63.117.24.31 comment="" disabled=no \
    interface=ether3 network=63.117.24.0
set allow-remote-requests=no cache-max-ttl=1w cache-size=8048KiB \
    max-udp-packet-size=512 primary-dns=84.235.7.55 secondary-dns=84.235.6.55
/ip firewall address-list
add address=192.168.0.0/16 comment="" disabled=no list=BOGONS
add address=10.0.0.0/8 comment="" disabled=no list=BOGONS
add address=172.16.0.0/12 comment="" disabled=no list=BOGONS
add address=169.254.0.0/16 comment="" disabled=no list=BOGONS
add address=127.0.0.0/8 comment="" disabled=no list=BOGONS
add address=224.0.0.0/3 comment="multicast - 224.0.0.0/3" disabled=no list=\
    BOGONS
add address=223.0.0.0/8 comment="" disabled=no list=BOGONS
add address=198.18.0.0/15 comment="" disabled=no list=BOGONS
add address=192.0.2.0/24 comment="" disabled=no list=BOGONS
add address=185.0.0.0/8 comment="" disabled=no list=BOGONS
add address=180.0.0.0/6 comment="" disabled=no list=BOGONS
add address=179.0.0.0/8 comment="" disabled=no list=BOGONS
add address=176.0.0.0/7 comment="" disabled=no list=BOGONS
add address=175.0.0.0/8 comment="" disabled=no list=BOGONS
add address=104.0.0.0/6 comment="" disabled=no list=BOGONS
add address=100.0.0.0/6 comment="" disabled=no list=BOGONS
add address=49.0.0.0/8 comment="" disabled=no list=BOGONS
add address=46.0.0.0/8 comment="" disabled=no list=BOGONS
add address=42.0.0.0/8 comment="" disabled=no list=BOGONS
add address=39.0.0.0/8 comment="" disabled=no list=BOGONS
add address=36.0.0.0/7 comment="" disabled=no list=BOGONS
add address=31.0.0.0/8 comment="" disabled=no list=BOGONS
add address=27.0.0.0/8 comment="" disabled=no list=BOGONS
add address=23.0.0.0/8 comment="" disabled=no list=BOGONS
add address=14.0.0.0/8 comment="" disabled=no list=BOGONS
add address=5.0.0.0/8 comment="" disabled=no list=BOGONS
add address=2.0.0.0/8 comment="" disabled=no list=BOGONS
add address=0.0.0.0/7 comment="" disabled=no list=BOGONS
add address=128.0.0.0/16 comment="" disabled=no list=BOGONS
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=forward comment="allow established connections" \
    connection-state=established disabled=no
add action=accept chain=forward comment="allow related connections" \
    connection-state=related disabled=no
add action=drop chain=forward comment="drop invaled connections" \
    connection-state=invalid connection-type="" disabled=no
add action=accept chain=forward comment="allow ping" disabled=no protocol=\
    icmp
add action=accept chain=forward comment="allow udp" disabled=no protocol=udp
add action=drop chain=forward comment="" disabled=no protocol=udp \
    src-address=192.168.0.1 src-port=67
add action=add-src-to-address-list address-list=spammer address-list-timeout=\
    0s chain=forward comment="Detect and add-list SMTP virus or spammers" \
    connection-limit=30,32 disabled=no dst-port=25 limit=50,5 protocol=tcp
add action=drop chain=forward comment="" disabled=no src-address=127.0.0.0/8
add action=drop chain=forward comment="" disabled=no dst-address=127.0.0.0/8
add action=drop chain=forward comment="" disabled=no src-address=224.0.0.0/3
add action=drop chain=forward comment="" disabled=no dst-address=224.0.0.0/3
add action=drop chain=forward comment="" disabled=no src-address=0.0.0.0/8
add action=drop chain=forward comment="" disabled=no dst-address=0.0.0.0/8
add action=drop chain=forward comment="BLOCK SPAMMERS OR INFECTED USERS" \
    disabled=no dst-port=25 protocol=tcp src-address-list=spammer
add action=drop chain=tcp comment="deny DHCP" disabled=no dst-port=67-68 \
    protocol=tcp
add action=drop chain=tcp comment="deny RPC portmapper" disabled=no dst-port=\
    111 protocol=tcp
    135 protocol=tcp
add action=drop chain=tcp comment="deny NBT" disabled=no dst-port=137-139 \
    protocol=tcp
add action=drop chain=tcp comment="deny cifs" disabled=no dst-port=445 \
    protocol=tcp
add action=drop chain=tcp comment="deny NFS" disabled=no dst-port=2049 \
    protocol=tcp
add action=drop chain=tcp comment="deny NetBus" disabled=no dst-port=\
    12345-12346 protocol=tcp
add action=drop chain=tcp comment="deny NetBus" disabled=no dst-port=20034 \
    protocol=tcp
add action=drop chain=tcp comment="deny BackOriffice" disabled=no dst-port=\
    3133 protocol=tcp
add action=drop chain=udp comment="deny TFTP" disabled=no dst-port=69 \
    protocol=udp
add action=drop chain=udp comment="deny PRC portmapper" disabled=no dst-port=\
    111 protocol=udp
    135 protocol=udp
add action=drop chain=udp comment="deny NBT" disabled=no dst-port=137-139 \
    protocol=udp
add action=drop chain=udp comment="deny NFS" disabled=no dst-port=2049 \
    protocol=udp
add action=drop chain=udp comment="deny BackOriffice" disabled=no dst-port=\
    3133 protocol=udp
add action=jump chain=forward comment="jump to the virus chain" disabled=no \
    jump-target=virus
add action=drop chain=virus comment="Drop Blaster Worm" disabled=no dst-port=\
    445 protocol=tcp
    135-139 protocol=tcp
add action=drop chain=virus comment="Drop Messenger Worm" disabled=no \
    dst-port=135-139 protocol=udp
    445 protocol=udp
add action=drop chain=virus comment="Drop Virus" disabled=no dst-port=593 \
    protocol=tcp
add action=drop chain=virus comment="Drop Virus" disabled=no dst-port=\
    1024-1030 protocol=tcp
add action=drop chain=virus comment="Drop MyDoom" disabled=no dst-port=1080 \
    protocol=tcp
add action=drop chain=virus comment="Drop Virus" disabled=no dst-port=1214 \
    protocol=tcp
add action=drop chain=virus comment="ndm requester" disabled=no dst-port=1363 \
    protocol=tcp
add action=drop chain=virus comment="ndm server" disabled=no dst-port=1364 \
    protocol=tcp
add action=drop chain=virus comment="screen cast" disabled=no dst-port=1368 \
    protocol=tcp
add action=drop chain=virus comment=hromgrafx disabled=no dst-port=1373 \
    protocol=tcp
add action=drop chain=virus comment=cichlid disabled=no dst-port=1377 \
    protocol=tcp
add action=drop chain=virus comment=Worm disabled=no dst-port=1433-1434 \
    protocol=tcp
add action=drop chain=virus comment="Bagle Virus" disabled=no dst-port=2745 \
    protocol=tcp
add action=drop chain=virus comment="Drop Dumaru.Y" disabled=no dst-port=2283 \
    protocol=tcp
add action=drop chain=virus comment="Drop Beagle" disabled=no dst-port=2535 \
    protocol=tcp
add action=drop chain=virus comment="Drop Beagle.C-K" disabled=no dst-port=\
    2745 protocol=tcp
add action=drop chain=virus comment="Drop MyDoom" disabled=no dst-port=\
    3127-3128 protocol=tcp
add action=drop chain=virus comment="Drop Backdoor OptixPro" disabled=no \
    dst-port=3410 protocol=tcp
add action=drop chain=virus comment=Worm disabled=no dst-port=4444 protocol=\
    tcp
    udp
add action=drop chain=virus comment="Drop Sasser" disabled=no dst-port=5554 \
    protocol=tcp
add action=drop chain=virus comment="Drop Beagle.B" disabled=no dst-port=8866 \
    protocol=tcp
add action=drop chain=virus comment="Drop Dumaru.Y" disabled=yes dst-port=\
    10000 protocol=tcp
add action=drop chain=virus comment="Drop MyDoom.B" disabled=no dst-port=\
    10080 protocol=tcp
add action=drop chain=virus comment="Drop NetBus" disabled=no dst-port=12345 \
    protocol=tcp
add action=drop chain=virus comment="Drop Kuang2" disabled=no dst-port=17300 \
    protocol=tcp
add action=drop chain=virus comment="Drop SubSeven" disabled=no dst-port=\
    27374 protocol=tcp
add action=drop chain=virus comment="Drop PhatBot, Agobot, Gaobot" disabled=\
    no dst-port=65506 protocol=tcp
add action=drop chain=virus comment="MS SQL WORM" disabled=no dst-port=1434 \
    protocol=udp
add action=drop chain=virus comment="Drop Client Virus" disabled=no protocol=\
    udp src-port=1877
add action=drop chain=virus comment="Drop Dabber.A-B" disabled=no dst-port=\
    9898 protocol=tcp
add action=drop chain=virus comment="" disabled=no dst-address=192.168.1.254 \
    dst-port=80 protocol=tcp
add action=drop chain=virus comment="" disabled=no dst-address=192.168.1.99 \
    dst-port=80 p2p=fasttrack protocol=tcp
add action=masquerade chain=srcnat comment="IP Nat" disabled=no \
    out-interface=ether2
add action=dst-nat chain=dstnat comment="Redirected Traffic to Squid PPPoE" \
    disabled=yes dst-port=80 protocol=tcp src-address=10.10.1.0/24 \
    to-addresses=63.117.24.0 to-ports=8080
add action=dst-nat chain=dstnat comment=\
    "Radius Manager Access from Public Access" disabled=no dst-address=\
    192.168.1.10 dst-port=80 protocol=tcp to-addresses=63.117.24.2 to-ports=\
    80
add action=dst-nat chain=dstnat comment="SSH Access from Public Network" \
    disabled=no dst-address=192.168.1.10 dst-port=2222 protocol=tcp \
    to-addresses=63.117.24.2 to-ports=2266
    "Telnet Acess from Public Network to Cisco LRE" disabled=no dst-address=\
    192.168.1.10 dst-port=23 protocol=tcp to-addresses=63.117.24.2 to-ports=\
    23
add action=dst-nat chain=dstnat comment="Webmin Access to Proxy server" \
    disabled=no dst-address=192.168.1.10 dst-port=10000 protocol=tcp \
    to-addresses=63.117.24.2 to-ports=10000
add action=dst-nat chain=dstnat comment="" disabled=yes dst-address=\
    192.168.1.254 dst-port=80 protocol=tcp to-addresses=63.117.24.2 to-ports=\
    80
    192.168.1.99 dst-port=80 protocol=tcp to-addresses=63.117.24.2 to-ports=\
    80
    192.168.1.10 dst-port=80 protocol=tcp to-addresses=192.168.1.10 to-ports=\
    8291
/ip firewall service-port
set ftp disabled=yes ports=21
set tftp disabled=yes ports=69
set irc disabled=no ports=6667
set h323 disabled=yes
set sip disabled=yes ports=5060,5061
set pptp disabled=yes
/ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
    cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
    600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
    parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
    0.0.0.0
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    192.168.1.254 scope=30 target-scope=10
add comment="" disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=\
    192.168.1.99 scope=255 target-scope=10
/ip service
set telnet address=0.0.0.0/0 disabled=yes port=23
set ftp address=0.0.0.0/0 disabled=yes port=21
set www address=0.0.0.0/0 disabled=yes port=80
set ssh address=0.0.0.0/0 disabled=no port=2266
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no \
    inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/ppp aaa
set accounting=yes interim-update=1m use-radius=yes
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
/radius
add accounting-backup=no accounting-port=1813 address=63.117.24.2 \
    authentication-port=1812 called-id="" comment="" disabled=no domain="" \
    realm="" secret=testing123 service=ppp,login,hotspot,wireless timeout=2s
/radius incoming
set accept=yes port=1700
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
    gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
    0.0.0.0 timeout=1m ttl=50
/routing ospf
set distribute-default=never metric-bgp=20 metric-connected=20 \
    metric-default=1 metric-rip=20 metric-static=20 mpls-te-area=unspecified \
    mpls-te-router-id=unspecified redistribute-bgp=no redistribute-connected=\
    no redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
    metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
    redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    timeout-timer=3m update-timer=30s
/store
add comment="" disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=Asia/Riyadh
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
    "jan/01/1970 00:00:00" time-zone=+03:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set fan-mode=auto use-fan=main
/system identity
set name=" Management Console"
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
add action=memory disabled=yes prefix="" topics=!pppoe
add action=memory disabled=no prefix="" topics=manager
add action=memory disabled=yes prefix="" topics=pppoe
add action=memory disabled=no prefix="" topics=firewall
add action=memory disabled=no prefix="" topics=pppoe,ppp,error
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
    0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
    none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=10
/tool e-mail
set from=<> password="" server=0.0.0.0:25 username=""
/tool graphing
set store-every=5min
/tool graphing interface
add allow-address=0.0.0.0/0 disabled=no interface=all store-on-disk=yes
/tool mac-server
add disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" keep-max-sms=0 reader-running=no secret=""
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 \
    filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=\
    yes interface=all memory-limit=10 only-headers=no streaming-enabled=no \
    streaming-server=0.0.0.0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
now my question is
  1. can i route yahoo messenger,skype, voip traffic to my dedicated 512 line and
all my borwsing traffic, P2P,SSL, rest to my 10 MB dsl line ?..
i did search n got ths mangle rule.
/ip firewall mangle
add action=mark-routing chain=prerouting comment=“Y! routing mark” disabled=
no dst-port=5050 new-routing-mark=Yahoo passthrough=no protocol=tcp
add action=mark-routing chain=prerouting comment=“MSN routing mark” disabled=
no dst-port=1863 new-routing-mark=MSN passthrough=no protocol=tcp
add comment=“” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=
192.168.0.1 routing-mark=MSN scope=30 target-scope=10
192.168.0.1 routing-mark=Yahoo scope=30 target-scope=10
is this working?? any one guide me steps to achieve my task… i need ur help, u can pm (ahfawad@hotmail.com) me if u have working configuration…
(i need to make sure my scenario works before applying for dedicated link as it is very costly , 3 months prepay and huge deposit)…
Thanx in advance…
any suggestions ??
how ur want to find skype traffic?
for routing some traffic on second channel ur should add mangle rule “mark-connection” with rules for select this trafic.
next ur should make mangle rule “mark-packet” which have “your connection-mark” and set on they “your routing-mark”
next add a default route (0.0.0.0/0) with needed gateway and routing-mak=“your routing mark”
