I’m using RB951G–2HND that is connected to Internet using PPPoE protocol. Almost everything is working perfectly except Active Directory that I’m facing problem because I’m not able to add the computer in the domain.
I also had problems with RDS, but it has been fixed using:
chain=forward action=change-mss new-mss=clamp-to-pmtu passthrough=yes tcp-flags=syn protocol=tcp
Regards
