PPPoE and DHCP servers same ports ?
CCR1036-8G-2S+ SFP+ is Internet (Public/Internet Routable IP) SFP+ 2 and Ports 3 - 8 are PPPoE . All addresses are public / internet routable there is no NAT or Private IP/Networks involved. Every device/host is given a public/internet routable IP address (we have a /22)
Currently have 7 PPPoE servers on 7 ports serving 7 segments / locations all using the same Profile / IP Pools. New owners want to be able to connect hosts with no config done (no setting up pppoe clients and DHCP is the default on the devices) in any of the 6 segments and have those devices on the internet. So an IP address assigned via DHCP over the same ports being used by PPPoE.
Can that be done ?
If so is it possible to have the DHCP use the same pools as the PPPoE or will I need to set up separate pools (can DHCP even use pools or just ranges ?) for each ?
