Hello all,
I am trying to setup a network in an ISP. This network requires that I deliver more than 2,5 Mbps over a PPPoE connection to our clients. The problem is in my tests I am not beeing able to provide more than 3,2 Mbps in TCP traffic. I tryed to change the kind and specifications of queue types but had no luck.
Best overal till now was using bfifo and queue size of 2904.
This is the test (I am using 4 routers, 2 making the PPPoE Server and Client session and 2 others in the border to test):
tool bandwidth-test direction=both duration=60s protocol=tcp user=admin address=192.168.3.237
status: done testing
duration: 1m1s
tx-current: 312.4kbps
tx-10-second-average: 298.0kbps
tx-total-average: 290.2kbps
rx-current: 3.5Mbps
rx-10-second-average: 3.4Mbps
rx-total-average: 3.5Mbps
random-data: no
direction: both
Config in the queue is like this:
/queue type
add bfifo-limit=2904 kind=bfifo name=teste
/queue simple
add burst-limit=500k/4500k burst-threshold=300k/3500k burst-time=6m/6m \
direction=both disabled=no interface=<pppoe-nata.teste@certto.com.br> \
limit-at=400k/4M max-limit=400k/4M name=queue1 packet-marks="" parent=none \
priority=8 queue=teste/teste target-addresses="" total-queue=teste
So I would like to understand or to get a configuration that would work for speed over 3 Mbps. Hope to have some help. Thank you all.
Regards,
Nataniel Klug
