PPPoE and multiple IP Addresses
I have a company connecting to my wireless network via a bridge. They want 5 Static IP Addresses. I have built the subnet on the mikrotik and applied the gateway to the interface and applied one of the ip addresses to the user profile and that works fine. But the other ip addresses don’t work. I know I’m doing something wrong but cannot figure it out. Any help would be greatly appreciated.
Mark Spencer
Look into useing the route feature of PPPoE, under the user secret on the PPPoE server
I’ll try that out and test it tomorrow
Ok, So I tried the route and that didn’t work. I may have the route wrong. My users subnet is say 10.10.10.192/29 the 10.10.10.193 is my wireless and I have forced address 10.10.10.194 on the user and added the route in the route check box 10.10.10.192/29 but it doesn’t work. Any idea’s?
ok, so I got this figured out. If I setup a static ip to my pppoe user and create a static route of the /29 subnet i was going to give that company, it works fine. so, there it is…
Sorry to dig up an old post but could you tell me how you got this working?
NTB
8o)
