PPPOE and PUBLIC IP
Hi all
I have 126 public IP. And i want to give my client’s
Here is my network
ISP------>MT1-------DMZ
-------LAN1
--------LAN2
MT2–PPPEserver1----clients
–PPPEserver2-----clients
I enabled masquerade on LAN2, and on MT2. A have PPPOE server enabled on MT2. I want do give public IP’s to PPPOE Clients.
ANY IDEAS WHO TO GIVE PUBLIC IP TO CLIENTS?
http://img383.imageshack.us/img383/9389/new14yq.jpg
HERE IS A PICTURE
Make a new pool for pppoe say pppoe-public from your public IP range
and reference that new pool in a new set of ppp profiles. Assign your
public customers in ppp-secrets or radius and associate them them with
one of the new public set of profiles. If they need fixed Ip addresses from
the pool then set each customer with a remote real address from the pool
in their ppp secret setting.. and it works fine. You need to have the pool
on the interface - say wlan2 and bypassed in hotspot if you are using that
in combination.
I try but notting.
I give 1 public ip on pppoe interface (interface for pppoe clients), and i give public ip to client but don’t work. I thing the problem is on NAT or Routing.
I add rule on MT1 to accept public ip’s from clinet on mt2.
