hi all
we use pppoe connection and can limit user’s speed but …
the problem is :
we can not set user quota as when we set it user can easily disconnect then connect again and get a new quota ..
any ideas ??
hi all
the problem is :
any ideas ??
and by user quota you mean…? Data limit? Time limit?
If you’re keen on implementing those i suggest you setup radius server…mikrotik user manager may be a good start!?
Data limit
If its to limit amount of data: /ppp secrets
If its to limit data rate: /ppp profile
http://www.mikrotik.com/testdocs/ros/3.0/aaa/ppp.php
Data rate can also be limited using queues.
http://www.mikrotik.com/testdocs/ros/3.0/qos/queue.php
